Mount 26 inch tires ???
06.12.2017, 02:17
Does somebody now can I mount 26 inch tires on Cforce 400 ?
I've search on web but cant find info on that
Sent from my SCL24 using Tapatalk
Re: Mount 26 inch tires ???
06.12.2017, 05:43
Bestimmt!
Aber ob du dann noch fahren kannst ...
06.12.2017, 12:23
Ich denke das es daran liegt, das noch niemand versucht hat 26 Zoll auf eine 450er zu machen. Auserdem wird es dann mit Sicherheit eng zwischen Reifen und Radkasten. Ich denke das es keine gute Idee ist!!!
06.12.2017, 15:23
naja, am Radkasten kann man ja auch noch etwas "wegbasteln", hier natürlich nicht, aber in Mazedonien gibt es vermutlich nicht so viele Regeln wie hier... :nix:
06.12.2017, 16:15
Hello. :winke:
Would you try this on the original 12" RIM?
And what do you want to achieve or improve?
According to the vehicle papers in Germany you are allowed to drive only 24 "tires.
If you want to drive 25 ", you have to register them first in the vehicle papers,
otherwise you will get problems with the police.
And if you mount bigger tires, your speedometer will show a wrong value.
Best Regards from the Farmer :daumen:
06.12.2017, 17:39
I want to mount 26 inch tires to increase ground clearance.
Thats its a idea.
07.12.2017, 11:08
Dear Vlatko.
I figured out that 26 inches of tires have exactly 5 cm more in diameter than 24 ", so 61cm to 66cm.
If you use the same rim of 12 ", you only have to measure, if the tires will fit under the wheel arch.
Or have a look on this side, this is maybe helpful.
https://www.reifensuchmaschine.de/reife ... echner.htm
Best Regards - Farmer Klaus :winke:
19.12.2017, 10:56
In this thread you can see a machine with mounted 26" tyres.
http://cfmoto-forum.com/400450-17/2016- ... questions/
It looks well and will fit.
20.12.2017, 20:54
I already have seen that picture. But I think it is a 25x10x12 rear and 25x8x12 inch. But anyway thanks for your time to help.Bild
Sent from my K01E using Tapatalk
